0 members (),
133
Mod | | | Forums66 Topics128,132 Posts1,056,729 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2020 Posts: 431 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 431 | The brake pedal of my '57 Panel is making contact with the metal floorboard and squeaking loud. Is there a grommet, or seal, for this? | | | | | Joined: Mar 2010 Posts: 10,298 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,298 | You need to check your cab supports to make sure the cab hasn't collapsed, or that the cab hasn't shifted due to loose cab hold down bolts.
| | | | | Joined: Jan 2020 Posts: 431 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 431 | You need to check your cab supports to make sure the cab hasn't collapsed, or that the cab hasn't shifted due to loose cab hold down bolts. Thank you. | | | | | Joined: Jan 2020 Posts: 431 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 431 | I checked the body, and nothing seems out of whack. But, the brake pedal rod is just barely making contact with the floorpan. I have temporarily wrapped the pedal rod with electrical tape to eliminate the screech, but I will definitely need to do a better upgrade. I even looked to see if I could slide the master cylinder/pedal assy back just a hair, but it doesn't look like that is an option. I will probably end up having to widen the opening in the floor. Not something I like doing on a vehicle that already has more holes in it than it did originally!  | | | | | Joined: Mar 2010 Posts: 10,298 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,298 | Is the pedal contact point at the side or the top or the bottom? Does the pedal have any wobble to it? Does your clutch pedal rub?
| | | | | Joined: Jan 2020 Posts: 431 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 431 | Is the pedal contact point at the side or the top or the bottom? Does the pedal have any wobble to it? Does your clutch pedal rub? It's at the top and it does not wobble. No clutch, it's auto, now (bummer). | | | | | Joined: Mar 2010 Posts: 10,298 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,298 | An easy fix would be to install slightly thicker rubber pads (or stock pads if your old ones are mashed with age) between the bottom of the cab and the front cab mounts. This will raise the cab enough to clear the pedal hole.
| | | | | Joined: Mar 2014 Posts: 4,504 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,504 | If it swings from the bottom, that pedal travels in an arc (naturally) and the rod connecting the swing arm to the pedal is also curved. Before I did anything else, I'd just adjust it where the swing arm meet the rod. Those don't normally get out of adjustment, but if you're replaced your front body support pads, it is very likely they've compressed just enough to make it rub a bit. Or just time might do it. Good luck!
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
