2 members (Bill Hanlon, Rich'sToys), 82 guests, and 2 robots.
Topics128,127
Posts1,056,678
Members48,452
Tonight I discovered that the new rear axle wheel cylinders I got for my truck (um, 4 years ago...) are ... THE WRONG ONES!!!
The ones I have (that were SUPPOSED to have fit a 2-speed axle out of a '51 6400) are marked as Wagner WC28661 -- anybody tell me what these are?
~ One of many.
That's weird. The Wagner # you gave is the same ones used on the GMC I had (Eaton 1350 axle). I just honed them and got cylinder kits from napa.
Man, those hubs are heavy.......... grin
*** GMC ***
what is the diamater of the cylinder? I noticed that my parts book had two sizes available for that year...
I've got a 52 two speed and have been looking for those wheel cylinders as well...
-Mike R.
here's what I gleened from my master parts catalog..
for model year 51'
rear wheel cylinders
Utility 1st type, 51-52
rear-front 1.5in diamater with 4 tapped holes
rear-rear 1.5 in diamater with 5 tapped holes
All-one-ton comercial (what my 2 speed has) 46-52
a single 1 3/8 in diamater wheel cylinder for each wheel. casting number 5450072
I couldn't find this part in the Wagner catalog my parts guy has, but I found the 3/4 ton listed had the same casting number but a different part number (not sure why)
there is also a 1.5 inch diamater listed for all utility 36-50 casting number 5300892
so if you can get the diamater of the wheel cylinder and the number of screw holes to mount it, maybe we can figure out what it is supposed to go too, or maybe it's just plain wrong for any stovebolt application. smile either way...
hope this helps...
I'm gonna go pick up what might be the right ones tommorrow (hopefully) and if they are, I'll get teh part number for you too.
-Mike R.
Oh, parts kits are available from CarQuest as well as NAPA.
Wheel cyls. can be sleeved.......... brakecylinder.com
*** GMC ***
Thanks Mike! The mounting holes were close but still not in the right spots to fit the backing plate. The biggest difference I could tell was that they didn't have the holes on the inside so you could connect the two cylinders together with the short line that runs behind the brake shoe mechanism.
Thanks for the other advice, too. But I've never had any luck with trying to do the brake cylinder kit thing. I wasted a lot on money when I did my '39's brakes so I learned a lesson and now when I redo brakes I chuck everything and buy new. As Barry Weeks says, there are two kinds of guys -- Mechanics and Parts Changers. I'm a Parts Changer.
Regards,
~ One of many.
sounds like you might have the 1-ton comercial type that was the one cylinder, instead of the 2 cylinder utility type.
what are the casting numbers on those cylinders? I might want to talk to you PM about them if they would work for my project... since they are not the right ones for yours...
-Mike R.
