3 members (Gdads51, JoergK., 1 invisible), 91 guests, and 3 robots.
Topics128,181
Posts1,057,150
Members48,464
My '57 panel has an OEM brake light switch on it, which is actually mounted down closer to the master cylinder at the driver's side floor.
I have a new, aftermarket, universal wire harness. Since I am not majorly concerned about originality, should I just get a newer style switch that would mount up over the brake pedal, since it would be compatible with the new harness? Or, other thoughts?
1957 Chevy Panel Truck, powered by SBC 350 from 1977 Camaro
Author, Bring CHANGE Into Your Life (a truly easy investment tool)
https://www.amazon.com/Bring-CHANGE-Into-truly-investment/dp/1077276869
Insomniac
Insomniac
The OEM brake switch simply controlled the brake lights.
Newer style switches add functionality. As well as controlling the brake lights, they may disengage the torque converter clutch, cruise control, etc. Do you need anything more than brake lights?
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Thanks for your response- nope, it would be for brakes only. I recall switches from the 80's/90s just being for the brake only, and having 2 tabs to connect to the harness with. I have not yet reviewed the one for this truck in-depth, but I just wanted to make sure that it would work with my newer harness from Speedway Motors without having to make alot of mods.
Riding in the Passing Lane
Either type brake switches will work fine. You may have to change connectors & length of the wires.
George
1972 Chevy c10 Cheyenne Super
You might need to source a bracket to hold the brake switch. Also, a place for the switch to be actuated. I'd hit up the wrecking yards, maybe find a pedal assembly that will fit your truck.
Another quality post.
Real Trucks Rattle
George
Thanks for the feedback- I just pulled out the instructions and it looks like it's just 2 wires, one for input, and one for output. I will look now to see if I can locate an OEM connector for the '57 truck switch. Thanks!
