3 members (DadsFirstPickup, Hotrod Lincoln, Otto Skorzeny), 163 guests, and 1 robot.
Topics128,131
Posts1,056,722
Members48,454
I'm going to have to replace most of the metal on my inner cowls. I'm curious, when replacing inner cowls, what do you do with the windlace channel that is installed on the surface of the cowl? Is it better to cut it off and replace that portion of the channel, or to avoid it and do a cut out and weld of the cowl metal only?
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1950 Studebaker Starlight Coupe
1947 Indian Chief
1943 Indian 741
I cut off the windlace channel and welded new sections on once I had the inner cowl panels on. I think it would be way more trouble to weld a joint near the channel. It's easy enough to plug weld new channel on by drilling holes in it for the plug welds to the inner cowl panels.
When I did mine, I left enough metal to each side of the windlace track and butt-welded the panels on that side.
