| | | Forums66 Topics128,281 Posts1,058,472 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2019 Posts: 123 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 123 | i bought a 54 3100. The previous owner had put chromed wheels on it with baby moon hubcaps. i got the original wheels and hubcaps. did they come out with chromed hubcaps or were they painted? If painted what color?the hucaps i have are painted and rusty. i can clean them up and repaint. The only ones i see from veners are chrome. Thanks Frank | | | | | Joined: May 2015 Posts: 11,278 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,278 | Page 89 of Brad's last link has color info. Although it doesn't mention hubcaps, it indicates that the bumper was painted Anvil Gray, so by association, hubcaps would also have been painted the same color from the factory. If your painted hubcaps are in decent shape, you can definitely clean them up and paint them. Anvil Gray is PPG code 32983 per Tim Lederman's excellent color tech tip page (I think that code under '54 is a typo)
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jan 2019 Posts: 123 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 123 | Thanks Looks like a lot of interesting information. Frank | | | | | Joined: Jan 2019 Posts: 123 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 123 | Do you know what the color code is for the blue in the bowtie? Thanks | | | | | Joined: Jan 2019 Posts: 123 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 123 | i have the bead blasted and worked on a few small dents. I think the will look pretty good with a fresh coat of paint. Thanks | | | | | Joined: Jan 2019 Posts: 123 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 123 | I learned something to day about the original hubcaps. tried to weld on spot near the rim. when cleaning up the weld there was separationat the weld. talked to a friend who had been in the body shop business for fifty years and he told me there was a thin covering over the base metal. Almost impossible to weld. will try to build up with jb weld. | | | | | Joined: Mar 2010 Posts: 1,660 Curmudgeon | | Curmudgeon Joined: Mar 2010 Posts: 1,660 | I made a copy of this information but unfortunately I don't have a name of the person who created it.
GM baby moons 1940 thru 1955, for cost savings, used the same steel base and a same separate skin (brass?). The skin surface stamping changed as required by the design department.
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM." | | | | | Joined: May 2015 Posts: 11,278 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,278 | Some my hubcaps have a stainless steel outer skin. Not impossible to weld, but harder than plain steel. Like the headlight rings, some are chrome plated brass and some are stainless steel. If brass, they would evaporate pretty quickly if heated with a torch to steel welding temperature.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jan 2019 Posts: 123 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 123 | thanks for the information. Since i am going to paint anyway, i am going to try jb Weld and the paint. there is only one of the three that ws this damaged. Good information. Thanks Frank | | | | | Joined: Jan 2019 Posts: 123 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 123 | Are the babymoons held on with clips like the 54's? | | | | | Joined: Jan 2019 Posts: 123 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 123 | Found the paint. Shopline 32983 JAU single stage urethane. PPG was very helpful in finding the paint and a local distributor. | | |
