7 members (Shaffer's1950, Steelonsteel, Hotrod Lincoln, 2-Ton, homer52, Tiny, mo2cyl), 112 guests, and 3 robots.
Topics128,049
Posts1,055,665
#1409347 05/10/2021 4:41 PM
i bought a 54 3100. The previous owner had put chromed wheels on it with baby moon hubcaps. i got the original wheels and hubcaps. did they come out with chromed hubcaps or were they painted? If painted what color?the hucaps i have are painted and rusty. i can clean them up and repaint. The only ones i see from veners are chrome. Thanks
Frank
It is year dependent on painted (Korean war shortages) or not, chrome was available in others.
https://www.flickr.com/photos/advance-design_parts_co/45097553812/in/album-72157698909942712/
Many of the ‘54 hubcaps I have seen were painted, but the vendors offer chrome.
https://www.flickr.com/photos/advance-design_parts_co/45113231582/in/album-72157698936735772/
There is a lot of information on your ‘54 here, I think hub caps are in here but there is a bunch to wade through?
https://www.gmheritagecenter.com/do...hevrolet-Trucks/1954-Chevrolet-Truck.pdf
Page 89 of Brad's last link has color info. Although it doesn't mention hubcaps, it indicates that the bumper was painted Anvil Gray, so by association, hubcaps would also have been painted the same color from the factory. If your painted hubcaps are in decent shape, you can definitely clean them up and paint them. Anvil Gray is PPG code 32983 per Tim Lederman's excellent color tech tip page (I think that code under '54 is a typo)
Thanks Looks like a lot of interesting information.
Frank
Do you know what the color code is for the blue in the bowtie? Thanks
i have the bead blasted and worked on a few small dents. I think the will look pretty good with a fresh coat of paint.
I learned something to day about the original hubcaps. tried to weld on spot near the rim. when cleaning up the weld there was separationat the weld. talked to a friend who had been in the body shop business for fifty years and he told me there was a thin covering over the base metal. Almost impossible to weld. will try to build up with jb weld.
Curmudgeon
Curmudgeon
I made a copy of this information but unfortunately I don't have a name of the person who created it.
GM baby moons 1940 thru 1955, for cost savings, used the same steel base and a same separate skin (brass?). The skin surface stamping changed as required by the design department.
Some my hubcaps have a stainless steel outer skin. Not impossible to weld, but harder than plain steel. Like the headlight rings, some are chrome plated brass and some are stainless steel. If brass, they would evaporate pretty quickly if heated with a torch to steel welding temperature.
thanks for the information. Since i am going to paint anyway, i am going to try jb Weld and the paint. there is only one of the three that ws this damaged. Good information.
Frank
Are the babymoons held on with clips like the 54's?
Found the paint. Shopline 32983 JAU single stage urethane. PPG was very helpful in finding the paint and a local distributor.
