8 members (Gdads51, frogfarmer, Hotrod Lincoln, rfs56trk, JoeDude, Jon G, TexasA&M48Truck, dt235sd), 139 guests, and 3 robots.
Topics128,038
Posts1,055,536
Members48,425
#1409314 05/10/2021 1:54 PM
PA OUTLAW
PA OUTLAW
Hello ALL just a quick question rebuildable tie rob ends . I disassembled both side's cleaned checked ball to see if it was outround was not bad .Installed new spring seat spring concaved puck BALL other puck then threaded end piece lightly greased by hand when assembly but to get the threaded end plug in were I can get a cotter key in to lock the threaded end plug it IS darn tight is there a torque speck or what am I doing wrong!!!!! I wish I had mic the old ones as I took them out dot I didn't could anyone advise me Thank you!!!!!!!! Both sides are tight THANK YOU!!!!!!!!!!!
jrhackett #1409338 05/10/2021 3:52 PM
Outlaw, sounds like this information will help you - I'm going to attach the instructions from the shop manual. This should help with your questions. Note that the left photo is the first "page", the middle is the second and the third (right photo) is the remaining information from the Shop manual. The "installation instruction" will provide some insight, I think. Tightening something up until it stops and then backing off until the cotter pin can be installed seems "strange" but that's what it says! Good luck and happy bolting.
Ron
Ron - - Dusty53
1954 Chevy 3604
