1 members (Sjm),
149
Mod | | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,947 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,947 | That's for a passenger car bell housing. A 1948-up 216 or 235 truck bell housing has the right bolt pattern for a T-5 without using an adapter. Jerry
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | An adapter like that makes the job a little easier but with some simple modifications you don't need it. These mods are covered in past posts & can be brought up with a search. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jun 2002 Posts: 150 'Bolter | | 'Bolter Joined: Jun 2002 Posts: 150 | Aahhhh...it looked familiar when I crawled under. Thanks. | | | | | Joined: Feb 2004 Posts: 29,947 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,947 | Since the lower bolt holes of a truck transmission are threaded, you'll need to use bolts and nuts there when installing the 5 speed. Some people use an aluminum spacer between the T-5 and the bell housing to avoid having to shorten the pilot bearing snout and lengthen the clutch splines on the input shaft. A fine spline clutch disc is also required unless you swap to a Jeep input shaft that has the same splines as a stovebolt clutch. Jerry
