10 members (DaveV, Joe H, Oswald, Phak1, GA Boy, 55shaker, Jay R, 32vsnake, Goach2, Ridgeback),
92
Mod | | | Forums66 Topics128,198 Posts1,057,270 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2016 Posts: 2 '51 Chevy Trucks | | '51 Chevy Trucks Joined: Sep 2016 Posts: 2 | Can anyone recommend the best door seal rubber to buy for my 1951 Chevy 2-ton 5100 cabover?
Steele has a lot of self-adhesive profiles. Is there a kit? A recommended thickness? Thanks.
1951 Chevrolet 3100 1/2-ton Pickup 5-speed 5-window 6-cylinder 235 :::::::::::::::::::: 1951 Chevrolet 5100 2-ton COE stake truck 4-speed 6-cylinder 261 :::::::::::::::::::
| | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | I seriously doubt you'll find a kit for a COE, but the door rubber seal should be the same profile as the conventional cab doors. The conventional cab door seal might work for 80% of the door and then just fill in the curve of the wheel opening... Mike B  | | | | | Joined: Sep 2012 Posts: 103 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 103 | the filling station sells the door seals by the foot. one door takes around 14 feet. the have two sizes one is thicker than the other. hope this helps chris | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Rick 51 3100 Just used my first steele back glass seal yesterday. Almost used some special english on it,finally "roped " it in there . rubber was expensive but soft and high quality. Was a new glasss from carter lubed with tire soap. | | |
