2 members (GMCJammer51, TUTS 59), 87 guests, and 1 robot.
Topics128,197
Posts1,057,267
Members48,466
'51 Chevy Trucks
'51 Chevy Trucks
Can anyone recommend the best door seal rubber to buy for my 1951 Chevy 2-ton 5100 cabover?
Steele has a lot of self-adhesive profiles. Is there a kit? A recommended thickness?
Thanks.
1951 Chevrolet 3100
1/2-ton Pickup
5-speed
5-window
6-cylinder 235
1951 Chevrolet 5100
2-ton COE stake truck
4-speed
6-cylinder 261
I seriously doubt you'll find a kit for a COE, but the door rubber seal should be the same profile as the conventional cab doors.
The conventional cab door seal might work for 80% of the door and then just fill in the curve of the wheel opening...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
the filling station sells the door seals by the foot.
one door takes around 14 feet.
the have two sizes
one is thicker than the other.
hope this helps
chris
Rick 51 3100 Just used my first steele back glass seal yesterday. Almost used some special english on it,finally "roped " it in there . rubber was expensive but soft and high quality. Was a new glasss from carter lubed with tire soap.
