| | | Forums66 Topics128,180 Posts1,057,165 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Doing a suspension lube and noted one of the dust covers was missing. Looks to be 1 1/8" dia. Anyone know where I can get one? Going to post request on parts wanted forum. Thanks
Ed
| | | | | Joined: May 2015 Posts: 11,163 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,163 | The ones in the king pin kit I have measure 1.11 inches and are domed by about 1/8" so they expand a bit when driven into place. You might find something similar at your FLAPS (like a core plug that's shaped the same.)
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Thanks for the measurement and the offer in "parts wanted" forum
Ed
| | | | | Joined: May 2015 Posts: 11,163 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,163 | You're welcome. Let me know if you can come up with one locally.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | The part number for a Melling 1 1/8" disc type freeze plug is MEP-10. It will fit the counterbore with a little careful grinding on the perimeter, and a firm tap with a hammer will expand it. Jerry
| | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Thanks Jerry, will check it out! Also found that Dorman 550-015 is also a very close fit, but very hard to find. Will advise what I come up with. Ed
Ed
| | | | | Joined: May 2015 Posts: 11,163 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,163 | Here's a seller of that Dorman plug. Not cheap though. Link
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | Search Ebay for "1 1/8" freeze plug". The Melling plug is listed there for $1.00- - - - -with a $5.00 shipping charge! Jerry
| | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Kevin, not cheap is right, seller confirms that is for one plug. Jerry, I think I'll give the $1 seller a shot. Again thanks for the help guys. Will keep you posted. Ed
Ed
| | | | | Joined: May 2015 Posts: 11,163 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,163 | Kevin, not cheap is right, seller confirms that is for one plug. Jerry, I think I'll give the $1 seller a shot. Again thanks for the help guys. Will keep you posted. Ed But the shipping is "free". [we definitely need a "rolleyes" emoji  ]
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | The Melling MEP-10 was a great fit. Took a little to get it in because of the location under the brake hose.Thanks Jerry. Hopefully this info will help another bolter down the road. Ed
Ed
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Forty9 The parts stores used to have Dorman drawers for stuff like that,they were just full of little parts you needed.Now I doubt your local FLAPS in nev. has that But ask about it. Also the alignment shops may know. Here I think old parts stores could find it. | | |
