1 members (moparguy),
113
Mod | | | Forums66 Topics128,266 Posts1,058,386 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2002 Posts: 150 'Bolter | | 'Bolter Joined: Jun 2002 Posts: 150 | Good Saturday, all y'all. How do you well knowledged sages deaden the expansive steel drum membranes attached to both sides of our AD trucks? I close the doors, hear the BOING ! !, and know it is going to be deafening going down the road when they start to vibrate. Not much access for either DynaMat or spray. Have a great day ! ! | | | | | Joined: Jan 2017 Posts: 308 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 308 | Old Trucks rattle--I love it. A 49 3 window and a 51 5 window............. | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Crowbar65 Be glad when they go in the hole and LATCH, I hate the noise too but it's AD world !!! | | | | | Joined: Feb 2019 Posts: 4,540 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,540 | I have heard that 4” wide window and door roll flashing works well. Small, self stick so it should be fairly easy to apply. I don’t think you have to cover the whole door, just get in as much as you can. The density of the flashing will absorb the oil can sound.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Aug 2019 Posts: 251 'Bolter | | 'Bolter Joined: Aug 2019 Posts: 251 | I stuck Dynamat (or similar sound damping material) to door and made a door panel (with seat matching fabric) to cover it. 1957 Chevy 3200Daily DriverPS, A/C, Tilt column, Rebuilt 350, Rebuilt TH350, Reupholstered Bench Seat, sound proof/insulated, LED headlights/taillights/backup lights/interior courtesy lights. Follow in the DITY | | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | I used a generic Dynamat on just the inside of the outer door skin. It was easy to do when all the window apparatus and latching mechanism were out. It has been quite effective. | | | | | Joined: Oct 2005 Posts: 4,263 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,263 | Cut your choice of sound deadener in to small pieces. Apply to the inside of the outer door skin. Contrary to popular belief, every square inch of sheet metal does not need to be covered. 1/3 or more coverage will work fine. Spreading out the pieces will help, too. | | | | | Joined: Mar 2007 Posts: 4,217 Moderator | | Moderator Joined: Mar 2007 Posts: 4,217 | Love the boing sound. My panel did that too, until the upholstery got done. | | | | | Joined: Jun 2002 Posts: 150 'Bolter | | 'Bolter Joined: Jun 2002 Posts: 150 | I used to do acoustic dampening design on aircraft interiors. Extraneous, mutable noise drives me crazy. Just wondered if there were any AD tricks. Might fab up a curved, or spring steel roller extension to aid in application of Dynamat. Just enough to halt the timpanic action. Still getting used to the different forum areas again.... Thanks | | | | | Joined: Oct 2005 Posts: 4,263 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,263 | | | | | | Joined: Sep 2010 Posts: 1,732 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,732 | I used stick on tape from the roofing dept at my box store. It's 6 inches wide on a 25 ft roll. Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Oct 2005 Posts: 4,263 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,263 | | | | | | Joined: Jun 2002 Posts: 150 'Bolter | | 'Bolter Joined: Jun 2002 Posts: 150 | No, just used that as a generic term for adhesive deadening sheets. | | |
