2 members (TexasA&M48Truck, Nick in Manitou), 124 guests, and 3 robots.
Topics128,082
Posts1,055,964
Members48,430
#1408973 05/07/2021 12:19 PM
V
VEW
Offline
V Offline
I'm working on the headlight assembly for the 41 and need help with the springs. As you can see, the springs are rusted and the brackets are riveted in.
What have you done or recommend to repair these? I don't know if springs are even available - haven't searched for them yet.
~ Victor
1957 3100 - moved on
If you can't find replacements, dunk the whole assembly in Evaporust to get rid of the rust, paint them and move on. They don't look that badly rusted to me.
VEW #1409052 05/08/2021 12:43 AM
Looks like the ends are broken off .there is one type on eBay but at 12 bucks looks like some newer springs look similar but better price but you would have to compare them. Some pics for comparison .
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
V
VEW
Offline
V Offline
Thanks for the leads! Looks like I will be able to make one of these work. The non-hooked end is riveted into the bucket and I was reluctant to drill out the rivet without knowing what direction to go in.
I had to remove the rivets from the headlight bucket to the housing yesterday to straighten out both parts. They got "rearranged" somewhere along the line in the last 80 years. They're now ready to go back together, but I'll change out the two springs before assembling. Might as well do the passenger side too.....while I'm at it. You know how that goes....
Thanks again folks!
~ Victor
