4 members (Gdads51, 1955 1 Series, Bill Hanlon, 1 invisible), 336 guests, and 6 robots.
Topics128,162
Posts1,057,068
Members48,463
please help, I pulled my king pins apart to rebuild and the new kit from napa will nor work. the new pin is 5 5/16" long and 7/8"thick. the old pin is just shy of 5 5/8" long and just shy of 15/16" thick. the new lower bearing is taller than the old layered bearing the came out of my truck. the truck is an 8 lug brake setup.
Those look like the ones on a half ton
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
They probably sold you a 1/2 ton king pin set. Take them back.
they have been returned, now to find the correct ones. Napa says they are discontinued 🤔
AD Addict & Tinkerer
Classic Parts carries them. Here is a [LINK].
Phil
Project Journals
Stovebolt Gallery Forum
I just ordered them, I had tried Brothers truck, LMC, chevysofthe40's but I guess classicparts is the one to go with. Thank you Phak1 for the link. I'll let you know how it goes.
I used the king pins from Classic Parts (#74-113 for the .921" dia. pins) for my '51 3/4 ton. They worked out great.
Brian
'51 Chevy 3604 Project
'28 Chevy LO basket case
'83 GMC Sierra 4x4
That's awesome Brian, I hope the ones I ordered will work too so I can get my truck back on the ground and rolling. 👴
thumbs_up
Phil
Project Journals
just got the king pins back from the machine shop getting the bushings pressed in and bored to match the pins. I just need to finish stripping and painting the axle and then back together. thanks again!
