| | | Forums66 Topics128,162 Posts1,056,925 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2000 Posts: 90 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 90 | Wondering if any vendor currently sells hubcap clips for 3/4 and 1 ton trucks from 50s and 60s? Have a classified ad up as well, just wondering if there's a repro source. I've seen the 1/2 ton size from a couple of different companies...could those work if I added a spacer? I understand that they are too short as is.
1959 Chevrolet 3800 Pickup 1937 Chevrolet GC Panel Can you still call it a barn find if it's your barn? | | | | | Joined: Jul 2019 Posts: 559 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 559 | I think they are all the same. The depth and diameter of the wheel center is what changes. Jim carter does not specify any different ones for 1/2,3/4,1t. Hub cap clip | | | | | Joined: Jun 2000 Posts: 90 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 90 | I checked the Jim Carter site and their clips are listed for 1/2 ton only. I have a couple off a passenger rim, which I think are the same as the 1/2 ton size, and they are too short to reach and hold the lip of the hub cap.
1959 Chevrolet 3800 Pickup 1937 Chevrolet GC Panel Can you still call it a barn find if it's your barn? | | | | | Joined: Jul 2019 Posts: 559 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 559 | Ohh your right. I just read the description at the bottom. I didn’t see that before. I stole mine off the original wheels luckily. They should be fairly simple to make if you have one as a template. | | | | | Joined: Jun 2021 Posts: 9 'Bolter | | 'Bolter Joined: Jun 2021 Posts: 9 | I added spacers and did some strategic bending to get the fit. I'm running Ford E-Series rims but they worked. | | |
