4 members (Phak1, TUTS 59, Southerntruck, 78buckshot), 78 guests, and 3 robots.
Topics128,151
Posts1,057,001
Members48,460
Wondering if any vendor currently sells hubcap clips for 3/4 and 1 ton trucks from 50s and 60s? Have a classified ad up as well, just wondering if there's a repro source. I've seen the 1/2 ton size from a couple of different companies...could those work if I added a spacer? I understand that they are too short as is.
1959 Chevrolet 3800 Pickup
1937 Chevrolet GC Panel
Can you still call it a barn find if it's your barn?
I think they are all the same. The depth and diameter of the wheel center is what changes. Jim carter does not specify any different ones for 1/2,3/4,1t.
Hub cap clip
I checked the Jim Carter site and their clips are listed for 1/2 ton only. I have a couple off a passenger rim, which I think are the same as the 1/2 ton size, and they are too short to reach and hold the lip of the hub cap.
Ohh your right. I just read the description at the bottom. I didn’t see that before. I stole mine off the original wheels luckily. They should be fairly simple to make if you have one as a template.
U
U Offline
I added spacers and did some strategic bending to get the fit. I'm running Ford E-Series rims but they worked.
Chris Elliott
1949 3600
Images in the Gallery Forum
4 Unimogs
1 48 CJ2A
