7 members (Bill Hanlon, Otto Skorzeny, 52Carl, Hotrod Lincoln, TooMany2count, chemanic, 1 invisible),
96
Mod | | | Forums66 Topics128,135 Posts1,056,418 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 393 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 393 | We removed the rear doors on my kid's '52 panel today. There's a bit of play in one pin otherwise the hinges dont seem too bad. Can new pins be pressed in after the old ones are pressed out? Are the pins special? Anyone have dimensions for the pins? Any other tips appreciated. Thanks.
It's a small world, but I wouldn't want to paint it.
| | | | | Joined: Feb 2019 Posts: 4,483 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,483 | Chev’s of the 40’s carry these repair kits, although not in stock at this time. They do have the dimensions listed. Here is the link. https://www.chevsofthe40s.com/detai...in_With_Bushings_Back_Door_Suburban.html
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Sep 2007 Posts: 393 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 393 | Thanks, Phil. I contacted Chevs of the 40s and they don't think they wil ever get them in as "no one's making them now." I may check out Doorman and see if I can match the dimensions
| | | | | Joined: Apr 2021 Posts: 1 Moderated | | Moderated Joined: Apr 2021 Posts: 1 | You can try the Filling Station, looks like they might have what you need. door hinge partshttps://store.fillingstation.com/shop/?year=1952&vehtype=Truck&search=hinge&searchtype=FT | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I had to rebuild my barn door hinges and had to re drill the holes on the drill press. I had to go a little oversized and ended "up using hinge pins for a dodge. I used 23/64' diameter hinge pins and cut them down to 2 11/16" long, beveling the end I cut off like original. The ribs at the top of the pin need to be at least 3/8" long and no more than 7/16" long.
1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
