4 members (TUTS 59, 2-Ton, Hotrod Lincoln, 1 invisible), 77 guests, and 4 robots.
Topics128,089
Posts1,056,356
Members48,442
#1404316 04/01/2021 11:44 PM
I have a 1960 Chevy C-10. I am attempting to replace the lower and upper bearing of the steering column shaft. The pic shows where I need help. I assume this race with the felt seal is all that is left of the original lower bearing and needs to be removed. Is that right? I took the rust off the shaft with an emery cloth and the new bearing slides on fairly easy.
With the advise of my mechanic I removed what was the old race and felt seal. That part solved. I now need the upper bearing/horn cable assembly. It's not available from LMC. I'll be checking with 456 Chevy as well as the sources listed on here. If anyone has a known source could you please post it on here?
Unconventional Thinker
Classic Industries has a ton of parts available. Take a look at their website. If you order from them, you can expect a nice fat catalog in the mail a little while later. I bought clutch fan blade and a 292 engine sticker from them a few months back, and about a week ago I got a nice catalog with parts for my '65 that I have been trying to find for years to no avail.
Shane
Shane's Toys...
2007 Forester XT Limited (2nd Owner)
1991 Cherokee Laredo (2nd Owner)
1981 Chevy 3/4 Ton Fleetside 8,600 Camper Special (3rd Owner)
1965 Chevy 3/4 Ton Fleetside (3rd Owner)
Page 98 of the Classic Industries catalog T221A (Current Catalog)
Both upper and lower column parts.
There is a phone number in the catalog - 1-800-854-1280
ClassicIndustries.com
Thanks for posting that up Dave.
Shane
Shane's Toys...
My pleasure. Happy to be able to pay back some of the assistance I have received over the years from people on this site.
Thanks everyone. Got the part. Fit perfectly.
Glad to hear it. :-)
My truck, a 65 C10, had this same issue. Many times the area on the steering shaft the lower bearing runs on is badly worn and the lower bearing or bushing replacement won't fix it. Plus, it's a hell of a lot of work to get the steering shaft out.
I fixed mine by installing a nylon bushing in the lower portion without taking the shaft out. It's been working well for 3 years now. It's not really a bushing, it's a nylon quick release tool.
[img]https://i.ebayimg.com/thumbs/images/g/oIUAAOSwLl5eRDK8/s-l200.jpg[/img]
See it in there? chug
[img]https://i.postimg.cc/PJqc1V2v/image.jpg[/img]
Thats a great idea! It is a pain but I had to replace the top one and the steering gear box also.
I’m late to post this info, but here it is for those interested.
I made a 4 part DIY over a year ago on how to refurbish and repair a 1963 C10 steering column. Many sections will apply to 1964-72 columns as well. The 1960-62 columns are different animals but still have similarities.
The original design of the lower bearing is not very good. A brass bushing or sealed lower bearing is much better.
The DIY has 4 sections. https://lugnutz65chevystepside.weebly.com/steering-column-page.html
Very nice write up Lugnutz. Good photos as well. I've done both a '63 and a '62 column. Most of what you show for the '63 will work for the '60-62 as well. Turn signals are a different critter though.
