6 members (Southerntruck, Nick in Manitou, 46 Texaco, Hotrod Lincoln, 2 invisible), 83 guests, and 2 robots.
Topics128,115
Posts1,056,633
Members48,450
Does anyone have a source for the axle hub gaskets chevy part number 3650732 or have a cross reference number?
Rear wheel hub cover gasket that keeps the axle shaft in?
That's not a particularly hard working gasket and it's easy to get to so low risk in making your own.
I like to use premade gaskets whenever available but some gaskets are just as easy to make, this would be one of them.
If you're still searching for the new gasket at the auto parts store I believe the same rear hub gasket with 5 holes were used on the 10 lug (wheel) 3500HD (the model with I-beam front axle) with Dana 80 or Dana 70HD.
•1952 Chevrolet 3800 pickup
---All pictures---
So far I've been able to find every part that I need, it takes some searching and luck but somebody has these gaskets sitting on a shelf. The local parts stores are pretty much worthless except NAPA. I'm taking one of the hub gaskets there today to try and match it up with some they have. I've got a source about an hour from me that has a warehouse full of old small parts, gaskets, bearings, seals, etc. But nothing is cataloged or indexed so it's like finding a needle in a haystack but I've always found what I needed. For me part of the fun of restoring the old beast is the search. I'm retired so time doesn't matter. Yes, I could make the gaskets but where's the fun in that?
I got both the front and rear gaskets at NAPA. Thanks Grigg for the tip, it made it easy to locate these gaskets.
Glad it worked out.
What part number did they end up being, and where did you get them?
---All pictures---
