1 members (Hotrod Lincoln), 60 guests, and 0 robots.
Topics128,050
Posts1,055,641
#1407397 04/25/2021 1:58 PM
My 59 is a 3 speed. Neighbor has an sm425 4 speed. If I use the 4 speed do I need a different driveshaft ?
Camino #1407410 04/25/2021 3:22 PM
If you are referring to the SM420 (granny gear 4 speed) the answer is yes.
Fred
Camino #1407431 04/25/2021 7:02 PM
Crusing in the Passing Lane
If a 465, also need new driveshaft.
Ed
Camino #1407511 04/26/2021 1:38 PM
Yes a 420. Thanks guys. I was afraid of that.
Camino #1407531 04/26/2021 3:20 PM
The SM420 is a good HD trans and would be great for hauling loads but is no improvement for normal driving.
If you are looking for better highway speeds, install an overdrive. The SM319 is a factory overdrive, it is a bolt in and no driveshaft or any other mods are needed. There are electrical components and a cable but that's it.
Fred
