| | | Forums66 Topics128,020 Posts1,055,345 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2014 Posts: 22 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 22 | My 59 is a 3 speed. Neighbor has an sm425 4 speed. If I use the 4 speed do I need a different driveshaft ? | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | If you are referring to the SM420 (granny gear 4 speed) the answer is yes. Fred
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | If a 465, also need new driveshaft.
Ed
| | | | | Joined: Jul 2014 Posts: 22 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 22 | Yes a 420. Thanks guys. I was afraid of that. | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | The SM420 is a good HD trans and would be great for hauling loads but is no improvement for normal driving. If you are looking for better highway speeds, install an overdrive. The SM319 is a factory overdrive, it is a bolt in and no driveshaft or any other mods are needed. There are electrical components and a cable but that's it. Fred
