9 members (MickeyP , Otto Skorzeny , sron48 , KCMongo , Nick in Manitou , mick53 , Gdads51 , Jaison , 1 invisible),
100
robots. Key: Admin ,
Global Mod ,
Mod
Topics128,050
Posts1,055,704
Most Online14,466Apr 26th, 2026
AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
over 30 years! and not clogged down with Ads! Again, thanks!
Can anyone I.D. this horn? Chevy, f#rd? If it's the second one it's out of here! Thanks for any help
1937 GC
It looks like one of the horns from a 37 Chevy car.
What does the relay switch box show for identification? If Chevrolet, it should have a stamp saying “DelcoRemy, I think. My guess is the horn is half of the set of town and country horns, but the brackets seem to be different than I’ve seen before. Maybe Tiny will chime in on this. I think I recall his ‘38 has a set of T&C horns?
Moderator
Moderator
I had that very horn in my 1953 panel, can't recall what brand it was but it worked good.
Ex Hall Monitor
Ex Hall Monitor
I don't know if the actual horns were used on more than one application but the bracket rules out the 37-38 accessory car horns.
Thanks for the replys. I guess it can stay on the shelf 😃
1937 GC
Crusing in the Passing Lane
I used the 6 volt horns on my ‘53 GMC on 12 volts, never had a problem. Ed
