7 members (Southerntruck, jaycoop, Joe H, WICruiser, 2-Ton, 42465967, Shade Baby), 114 guests, and 3 robots.
Topics128,129
Posts1,056,362
Members48,441
#1407175 04/23/2021 12:51 PM
Changing the rear wheel cylinders ( Huck brakes) on my 49 3100. Continuing to use Dot 5 fluid. Should I use brake fluid to lube the rubbers and cylinder wall or is there a better alternative? Thanks Ed
Ed
Moderator, Electrical Bay
Not one I've ever found.
~ Jon
7
7 Offline
Brake fluid is the only recommended lube.
They are correct, unless you use a product specifically made for that purpose.
Thanks for the input. I'll stick with brake fluid.
Ed
The nice thing about brake fluid, except for DOT 5 which exhibits more compressibility, is that it absorbs moisture. So the brake fluid left exposed after using it as an assembly lube will start causing corrosion right away. Like between the cup and the boot. Which eventually damages the steel, then the cup and causes leaks. Then wheel cylinder failure.
I agree with Mark, I only use "Brake Assembly Lube" and do my best to keep the DOT-3 OFF of everything else because it eats paint and starts premature corrosion.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
I'll continue to use Dot 5 in my system, don't think there will be issues like Dot 3/4.
Ed
You'll be fine with DOT 5.
2 Offline
Some old timey service documents make reference to using mineral oil to lubricate brake parts at assembly with implication that it was the method used by GM factory.
-s
-s
The 47-53 service manual has a note on brake cylinder disassembly that says "Do not use gasoline, kerosene, or any other cleaning fluid that might contain even a trace of mineral oil." which implies that mineral oil is not good.
It also says to "dip internal parts in brake fluid" on assembly.
2 Offline
Ah then they must of changed their mind on mineral oil
Perhaps there was an incident smile
If I find the document that said to use it I’ll try to remember to post it for interest sake
But by all means done use that stuff then!
-s
Some brake fluid is still made of mineral oil, for what it is worth. Most today are ether/glycol (except for DOT5 which I think is silicone based), but LHM stands for Liquide Hydraulique Mineral. What I've seen is green and it won't absorb water.
~ Jon
Riding in the Passing Lane
I use a thin film of silicone grease. It may not desolve in the brake fluid but a small amount will never hurt anything. It is really slick.
George
1972 Chevy c10 Cheyenne Super
