4 members (Still At It, 3800GUY, Bill Hanlon, Otto Skorzeny), 113 guests, and 2 robots.
Topics128,134
Posts1,056,402
Members48,441
I'm having a hard time finding the replacement ball for the steering arm on my 46 2 ton. It has a bigger stud than the idler arm, which is the same as the 1/2 ton. Anybody know where to find one?
Have you checked with The Filling Station? They have a set of balls for the drag link, and one of them has a larger diameter shaft. I put in a set on my 1/2 ton, but didn't measure the stud diameter. One was the same size as the tie rod connections and the other was a bit larger. They could probably tell you the size of the studs if you gave them a call.
They had what i needed, thank you
