| | | Forums66 Topics128,078 Posts1,056,046 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2021 Posts: 10 'Bolter | | 'Bolter Joined: Jan 2021 Posts: 10 | I'm having a hard time finding the replacement ball for the steering arm on my 46 2 ton. It has a bigger stud than the idler arm, which is the same as the 1/2 ton. Anybody know where to find one? | | | | | Joined: May 2015 Posts: 11,063 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,063 | Have you checked with The Filling Station? They have a set of balls for the drag link, and one of them has a larger diameter shaft. I put in a set on my 1/2 ton, but didn't measure the stud diameter. One was the same size as the tie rod connections and the other was a bit larger. They could probably tell you the size of the studs if you gave them a call.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jan 2021 Posts: 10 'Bolter | | 'Bolter Joined: Jan 2021 Posts: 10 | They had what i needed, thank you | | |
