1 members (Bill Hanlon), 137 guests, and 9 robots.
Topics128,078
Posts1,056,027
Members48,433
Anybody know what would cause my driver side taillight to be brighter than my passenger side? Then when I try to use the turn signal the driver side is just a faint flash whereas the passenger side is a good steady flash. I get the same result whether I use LEDs or incandescent bulbs. I've got a stronger flasher can in my fuse panel. When I use an incandescent bulb it looks like only one strand of the brake/turn signal wire is working, and it's much brighter
"The greatest use of life is to spend it on something that will outlast it" ~ William James
'25 Chevy Superior
'66 Chevy C10
'03 Chevy Silverado 1500 HD
Run a long ground write from the battery to the tail light.
You might have a weak ground for that light.
AD Addict & Tinkerer
Sounds like the wires on the drivers side are switched. The running light circuit is wired to the signal bulb and the signal light circuit is wired to the running light bulb.
Phil
Project Journals
Stovebolt Gallery Forum
Definitely check and clean the grounds, maybe add a ground from the housings to the body panel.
Another quality post.
Real Trucks Rattle
Phak1, I think you had it. I just went to plug and switched the connector around and it works fine now. Thanks for the advice....all of you, I appreciate it. It still won't work with LEDs, but at least the incandescent is working corrrectly.
'25 Chevy Superior
'66 Chevy C10
Excellent! Glad to help! thumbs_up
Phil
Project Journals
LED lights require a special LED flasher to work properly.
Phil
Project Journals
