5 members (2-Ton, Peggy M, Bill Hanlon, Woodcmiami, 1 invisible), 164 guests, and 2 robots.
Topics128,167
Posts1,057,015
Members48,458
#1406016 04/14/2021 11:27 AM
Hello, I have a 1951 1/2 ton GMC pickup. I'm installing new rear axle seals and bearings as part of a larger project.
I assume I need to pour some gear oil on those bearings after install but stop there. It looks like I do NOT pack them with bearing grease. The shop manual says they get their lubricant from the rear axle.
Sorry for the dump question. I'm just used to packing bearings before install. I appreciate any advice.
Mike
AD Addict & Tinkerer
You and the manual are correct. They do get their lubricant from the rear end.
Just lube them with gear oil and assemble!
Phil
Project Journals
Stovebolt Gallery Forum
Thank you Phil
It's important to make sure your axle oil level is correct. If you'll notice, on most axles, the fill/level plug on axles are slightly above the bottom of the axle tubes. Gear oil may be slow, but eventually, it will make it's way out to the bearing to keep them lubed.
Mike, is this Dana/ Spicer axle of G.M. corp. G.M. used c locks to hold axles in Dana has brg pressed onto axle, flange w 4 bolts hold axle in. In short, Dana has sealed axle bearing. On G.M. axles I line to fill it the jack each side up one at a time to get oil down the tube & out to the bearing, then recheck fluid level with it flat.
BC
1960 C60 pasture art
