3 members (Jay R, Phak1, walter74), 70 guests, and 4 robots.
Topics128,180
Posts1,057,164
Members48,465
Hi
I am looking for a washable KN air filter for my original GMC truck but I do not find it in a shop that sells to Germany.
The filter should be stock see picture.
Who knows where to buy it.
Giorgio
1955 GMC 102 Long Bed
Hamburg, Germany
More pictures in the Gallery Forum
Socket Breaker
Socket Breaker
Do you have any original part numbers? Current part numbers?
i have nothing , bought the truck as it is.
The filter has no partnumber on it and the only thing i am able to provide are the measurements of the filter.
Hamburg, Germany
K & N Filters by Dimension
K & N has 30+ dealers within 25 miles of Hamburg according to their dealer search page and it appears that the USA website can ship to Germany also.
SimS
That air cleaner has been modified to use a paper cartridge. The original air filter assembly would have been an oil bath type. Likely the best you can do at this point is to find something that fits by dimensions.
Fred
Provide some dimensions of the current filter, if you are trying to find a K&N replacement.
Craig
The dimensions are 3"height, inner diameter 6,37" and outer diameter 8"
Hamburg, Germany
K&N #E-1000 ?
OD 7.75" x 6.37" x 3"
Craig
It seems to fit and I will try to order it here in Germany because online it says 0 stock.
Thanks I will let you know if it works
Hamburg, Germany
Received it today and it fits.
Thank you very much
Hamburg, Germany
