1 members (Hotrod Lincoln),
92
Mod | | | Forums66 Topics128,132 Posts1,056,729 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2018 Posts: 34 'Bolter | | 'Bolter Joined: Jan 2018 Posts: 34 | Got my kingpins in and shimmed up nicely, now about to put the axle back. How much side-side play is typical with leaf springs? i.e. how do I know if it needs bushings? Thanks, Sammy
Marc S Houston TX 1946 Chevy 1/2 Ton
| | | | | Joined: Feb 2019 Posts: 4,496 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,496 | Any side to side movement is going to make the truck squirrelly going down the road. Best to change anything that is loose while you got it disassembled.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Any side to side movement is going to make the truck squirrelly going down the road. Best to change anything that is loose while you got it disassembled. Amen, Phil | | | | | Joined: Jan 2018 Posts: 34 'Bolter | | 'Bolter Joined: Jan 2018 Posts: 34 | Well I got a new bushings and shackles and all the stuff, and re-assembled. Wow! what a difference in how tight it is compared to before. Can't wait to drive it but waiting on a drag link rebuild kit first. Thanks for the info. -Sammy
