Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (Phak1, Gdads51, Otto Skorzeny, 1955 1 Series, Stovebolt48, Guitplayer), 34 guests, and 2 robots.
Topics128,022
Posts1,055,272
Members48,418
#1405517 04/10/2021 10:08 PM
I finally had some time to test a couple carburetors on my air flow bench. I used a Superflow 110. The adaptor I have use has a 4" bore, 6" tall, and is what I use when flow testing heads. For this test I made up a fixture to hold the carburetors in the center of the bore.
I drilled the wood so the hole was slightly bigger then the Carter W-1 base gasket that comes in the rebuild kits. The W-1 is 483.
Just the hole in the wood flowed 245 cfm @ 10".
The W-1 flowed 189 cfm @ 10". ( wide open throttle, choke wide open as well )
I then opened the hole up to fit a Rochester Monojet from 1970.
The Monojet flowed 215 cfm @ 10".
The bigger hole will flow 269 cfm.
I reinstalled the W-1 and got the same 189 cfm.
It's not a 100% accurate test, but it gives you some idea what is going on.
To convert the 10" test load to the original 3", multiply by .548
