| | | Forums66 Topics128,088 Posts1,056,122 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#14053 11/06/2002 5:45 AM | Joined: Aug 2001 Posts: 17 Member | | Member Joined: Aug 2001 Posts: 17 | I just pulled apart an engine but can't find info on the crank. The heads and block were easy but the crank is difficult. Does anyone know of a source that could help me ID this thing? I've tried all the internet sources I think.
Chevy SB V8 crank #14088528. It was out of a newer motor (87-95 #14093638).
Thanks!! | | |
#14054 11/06/2002 7:32 PM | Joined: Apr 2002 Posts: 11 Member | | Member Joined: Apr 2002 Posts: 11 | casting book claims: Block casting #14093638 - 350 86-87 truck or 87 Camaro
Crank casting #14088528, can't find...
crank casting #14088526 - 305 85-89 truck, 350 86-89 truck, 305 86-89 passenger, camaro, monte carlo, 350 87-89 camaro, corvette,
sorry couldn't be more help.
63 K10 Fleet 454
#14055 11/06/2002 10:54 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Why are you trying to ID the crank if you know what engine it came out of? If you are trying to figure out if its a cast or forged crank, you can look at the parting line where it was formed.
One has a narrow parting line, and the other has a much wider parting line where the crank's mold came together. Hope somebody can remember which is which.
good luck
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#14056 11/09/2002 8:41 PM | Joined: Aug 2001 Posts: 17 Member | | Member Joined: Aug 2001 Posts: 17 | Yea, I'd like to know if it is forged or not. The engine was from a 70's truck (obviously swapped). I'll look for those lines and maybe swing it by the local machine shop just to be sure. Thanks for the help! | | |
