6 members (tesa, 55shaker, Shade Baby, Gray_Ghost, LAROKE, Wally / Montana), 120 guests, and 2 robots.
Topics128,076
Posts1,055,922
Members48,430
#14053 11/06/2002 5:45 AM
I just pulled apart an engine but can't find info on the crank. The heads and block were easy but the crank is difficult. Does anyone know of a source that could help me ID this thing? I've tried all the internet sources I think.
Chevy SB V8 crank #14088528. It was out of a newer motor (87-95 #14093638).
Thanks!!
#14054 11/06/2002 7:32 PM
casting book claims:
Block casting #14093638 - 350 86-87 truck or 87 Camaro
Crank casting #14088528, can't find...
crank casting #14088526 - 305 85-89 truck, 350 86-89 truck, 305 86-89 passenger, camaro, monte carlo, 350 87-89 camaro, corvette,
sorry couldn't be more help.
63 K10 Fleet 454
#14055 11/06/2002 10:54 PM
Why are you trying to ID the crank if you know what engine it came out of? If you are trying to figure out if its a cast or forged crank, you can look at the parting line where it was formed.
One has a narrow parting line, and the other has a much wider parting line where the crank's mold came together. Hope somebody can remember which is which.
good luck
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#14056 11/09/2002 8:41 PM
Yea, I'd like to know if it is forged or not. The engine was from a 70's truck (obviously swapped). I'll look for those lines and maybe swing it by the local machine shop just to be sure.
Thanks for the help!
