1 members (Shade Baby), 58 guests, and 5 robots.
Topics128,271
Posts1,058,314
Members48,485
#1404987 04/06/2021 3:18 PM
Currently building a tubular steel run stand for a 235 and assembling parts and pieces. To avoid robbing my foot stomp starter (6 volt starter in 12 v system ) off the truck I am shopping for a used starter. I have a spare bellhousing off an early 60`s 235 engine. My question is: Can I mount any 235 Chevy starter either with foot stomp or electric solenoid for this application? It may be a little less convenient to use the stomp switch vs an electrified solenoid but will either work?
1953 3100 Pu
Swami29 #1404989 04/06/2021 3:45 PM
Yes, cars with 235 engines used a solenoid type starter up through 62. Trucks 60 through 62.
Fred
Swami29 #1405004 04/06/2021 5:48 PM
I used a stomp switch to turn over an engine sitting on a tire. I put a flip switch between the battery and coil to kill it.
Another quality post.
Real Trucks Rattle
Swami29 #1405034 04/06/2021 9:55 PM
Insomniac
Insomniac
I think you should read this: http://devestechnet.com/Home/Flywheel
Gord 🇨🇦
1954 1/2 ton 235 4 speed
