6 members (Otto Skorzeny, ShopRag, Gdads51, 55shaker, 78buckshot, Woogeroo), 147 guests, and 3 robots.
Topics128,268
Posts1,058,382
Members48,485
#1404974 04/06/2021 2:00 PM
Hello all.
Re: Stone stock '53 3100.
Can I install a 12 volt battery to kick the starter over and install a 6 or 8 volt shunt in the main power line?
If so, does anyone have a part number?
I plan doing a 12V conversion after I get the truck running and sorted out.
And all dispersions and advice welcome.
Thanks.
Crusing in the Passing Lane
A 6 volt starter will work fine on 12 volts, just don’t lay on it.
You need to provide only 6 volts, however you do it, to the fuel gauge, otherwise you will kill it, should be a colored tag on the terminal advising that fact, Jim Carter truck has that resistor for gauge. Resistor to feed heater, wipers, etc. Change bulbs.
There used to be a square ceramic resistor(about 4” x 4” square) no longer in production that had several taps, however they appear from time to time.
Ed
Read our Tech Tips Page on 6v to 12v conversion. Easy job and not too expensive.
Roger that.
Just wanted to get it running NOW (kid with new toy syndrome) without having to buy a six volt battery.
I'll relax and check the tech.
Thanks.
Crowbar 65 Would do the 12v conversion now and go right ahead with bulb change,1 wire alt,HEI, starter will work fine,NAPA for heater resistors,gas gage resistor at the vendors. Nice clean changeover !! 12 volt will really whip it over,my 7 are all that way.
