6 members (Chris's 46 / 515, Peggy M, Hotrod Lincoln, JW51, Otto Skorzeny, 1 invisible), 86 guests, and 1 robot.
Topics128,042
Posts1,055,597
#1404932 04/06/2021 2:13 AM
my 54" 3100 is very hard to steer, i want to upgrade to power steering. i have radial tires on already, but backing up is going to tear my left shoulder apart... lol i spoke to tucker classic parts and they suggested upgrading to IFS w/rack and pinion as apposed to keeping the stock axle and putting a power steering box kit in. i figured not to do all the work installing an IFS now, i could accomplish the p/s box much faster, get to drive it for now and take on the IFS project later on. any thoughts????
1954 Chevy 3100 with a straight 6cyl
Before committing to P/S, has the steering been rebuilt? New tie-rod ends, drag-link ends, king pins, and the steering box rebuilt will make a huge difference in how they drive and steer. Tire air pressure and tire width also makes a difference. If you choose to go with P/S, the linkage and king pins still need to be rebuilt. Someone will come along with the parts you will need for the upgrade, I have seen Toyota gear boxes mentioned but I don't know for what years. There are ways to add the power assist with out cutting the truck apart. Rack & Pinion on straight axles don't go together, it really makes for some less than ideal steering columns.
Crusing in the Passing Lane
There is a somewhat new power steering box that mounts in the existing location, existing mount bolt holes, gold colored steel mount plate, look in CPP, Classic Parts, some other places. Need to install pump on your own.
Ed
Moderator, Electrical Bay
What Joe said is very important...particularly about tire width.
~ Jon
Crusty Old Sarge
Crusty Old Sarge
The CPP kit Ed referenced is https://www.classicperform.com/Store/1960_1972_Chevy_Truck/CPP5559PSK-OC.htm . You would also need to add a power steering pump and bracket as well as additional pulleys to make it all work.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Insomniac
Insomniac
If and when I install power steering, I would seriously consider electric as discussed: https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/1341817/2.html
Gord 🇨🇦
1954 1/2 ton 235 4 speed
