7 members (Jon G, Youngin' Tut 59, Lightholder's Dad, Ponchogl, 3 invisible), 121 guests, and 3 robots.
Topics128,132
Posts1,056,384
Members48,441
#1399195 02/27/2021 11:18 PM
OK guy's I have another question. Where is the 4.10 stamp on the carrier that says It is actually 4.10 gears??
Someone posted it, But I can't remember where I saw it.
Any help would be great
Elmo
Elmo #1399204 02/28/2021 12:41 AM
Its Usually not that easy. But easy in a different form. Usually da teeth count is stamped on da ring gear. Devide one into da other and thats da answer. Or count da ring and pinion teeth yourself. Easy peasy. cool
Elmo #1399206 02/28/2021 12:45 AM
Ok got it, Thank you
Elmo #1399216 02/28/2021 1:10 AM
But isn't it stamped on the housing or on the ring gear some where??
Elmo #1399227 02/28/2021 1:56 AM
Somewhere on the circumference of the ring hear, the numbers 41-10 should be stamped- - - -41 tooth ring gear, 10 tooth pinion, which divides out to a 4.10:1 gear ratio. Other brands of gears (not GM) can have a 9-37 tooth count, for a 4.111111 ratio.
Elmo #1399231 02/28/2021 2:20 AM
Somewhere stamped on the Carrier you will find the Identification Code. Example, a 1967 C20 with 4.11 ratio would be stamped "HW". Note these codes were not always the same year after year, so get the code and report back so we can help figure out what you have.
The 4.11 ratio would have a tooth count of 37-9 (stamped on the ring gear)...37 divided by 9 = 4.11.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Elmo #1399387 02/28/2021 11:20 PM
I got one!!!! Finally! I found in Wausau Wisconsin. I had to go for a 2-1/2 hour drive yesterday. I am so stoked. And it only cost me 125.00 bucks. I could have gotten one in Iowa. But that would have been a 5 hours away.
ELMO!!!
Elmo #1399400 03/01/2021 12:08 AM
2.5hr cruise is well worth it. Best part is its a pretty easy upgrade.
Elmo #1404134 04/01/2021 12:38 AM
I finally got the chance to switch out my 3rd member in my 53 3600 3/4 ton truck last week end.I got my 4.11 gears now!!!! Woot Woot. I took the truck for a spin last night. No more screaming down the road at 50 miles an hour. It was a great day. I am so stoked!!!
Elmo!!
Elmo #1404290 04/01/2021 8:55 PM
Its a odd test drive. You know it’s different but its not a huge difference on paper or even seat of the pants but its just enough of a difference where it really does tame the rpm down. Im running a LS so mine can rev cross country at 5k if i wanted to without worry but i can see how on a old straight 6 it probably makes a much more noticeable difference.
Elmo #1404326 04/02/2021 12:28 AM
24601
Barnfind -- in my case, before I reengined to the 261 ... the 4.10 upgrade with the 216 was incredible. But ... the poor 216 ran out of oompah. It could hold 65 until the slightest hill or bump came along. Or a slight head wind ... But on the flat, the 216-powered 3804 could hit 70 and cruise (mostly) at or above 60. It just had no power. the 261 fixed all that wink
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Elmo #1404336 04/02/2021 1:31 AM
ELMO!!!
Elmo , what was the original rear end ratio .
good planning is no substitute for dumb luck
Elmo #1404346 04/02/2021 2:26 AM
Panel Fan, It is a stock 53 chevy 3600 3/4 ton. I believe the stock gears were 4.56! Something like that.
And I don't have a 216
I have a 235, I'm gonna take the truck out tomorrow after work and see how well it drives on the highway.
Woot Woot!!!!
Elmo #1408781 05/05/2021 11:22 PM
Unconventional Thinker
How did it do? I just discovered that I had a 4.11 3rd member in my possession all along. It was sitting under my parts truck tucked away inside the axle housing. If the bearings and everything check out, mine will be going from 4.57 to 4.11 in a week or two.
Shane
Shane's Toys...
2007 Forester XT Limited (2nd Owner)
1991 Cherokee Laredo (2nd Owner)
1981 Chevy 3/4 Ton Fleetside 8,600 Camper Special (3rd Owner)
1965 Chevy 3/4 Ton Fleetside (3rd Owner)
Elmo #1408849 05/06/2021 2:07 PM
Lol. Its almost like the Gods of good stuff were smiling down on ya. I like finding stuff i forgot i have. I just wish i could find it when i needed it. Ha
For sure! It was definitely a game-changing find. Now I am sourcing 14 bolt brake items so I can swap on 14 bolt brakes to the HO52 axle. HA! Find it when you need it, that is just not in the cards, it is always MIA when you need it, and then magically appears once you buy a new one or don't need it anymore...lol...
Shane
Shane's Toys...
