4 members (Leo, RLB, Ponchogl, Lostbuthaulinass), 78 guests, and 2 robots.
Topics128,049
Posts1,055,743
#1399269 02/28/2021 12:07 PM
Anyone have a copy of Tom Langdon's "installation and tuning" document for the carburetors they can share?
I am having trouble getting my truck to start. I have to hit it with starting fluid to get it to start. After it warms up. I have no issues getting it restarted. I have done a complete tune up and to no avail I can't seem to figure out what the issue is.
I have been tinkering with it now for a while thought at this point would be best back everything out and start over.
Thanks Steve
What choke control do they have?
How is it set?
Turn your mixture screw all the way in clockwise, then back it out 1.5 turns. Then adjust it to sound best. Then adjust idle speed.
1953 GMC 1-Ton Pickup with 350 and 700R4
AD Addict & Tinkerer
I’m onboard with panic, sounds like a choke issue to me.
Phil
Updated to: ā€˜59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc Brakes
Project Journals
Stovebolt Gallery Forum
smoloney Is your accelerator pump squirting fuel in the carb throat,if so should start !!
Also are you pushing the pedal to the floor once before you start?
