| | | Forums66 Topics128,051 Posts1,055,732 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2013 Posts: 165 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 165 | Anyone have a copy of Tom Langdon's "installation and tuning" document for the carburetors they can share?
I am having trouble getting my truck to start. I have to hit it with starting fluid to get it to start. After it warms up. I have no issues getting it restarted. I have done a complete tune up and to no avail I can't seem to figure out what the issue is.
I have been tinkering with it now for a while thought at this point would be best back everything out and start over.
Thanks Steve | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | What choke control do they have? How is it set? | | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 | Turn your mixture screw all the way in clockwise, then back it out 1.5 turns. Then adjust it to sound best. Then adjust idle speed.
1953 GMC 1-Ton Pickup with 350 and 700R4
| | | | | Joined: Feb 2019 Posts: 4,475 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,475 | Iām onboard with panic, sounds like a choke issue to me.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ā59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | smoloney Is your accelerator pump squirting fuel in the carb throat,if so should start !! | | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 | Also are you pushing the pedal to the floor once before you start?
