1 members (klhansen),
153
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,126 Posts1,056,356 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2020 Posts: 71 'Bolter | | 'Bolter Joined: Nov 2020 Posts: 71 | I have my distributor to a two wire magnetic pickup. I am using my FITech fuel injection to control my engine timing in my 235. My question is does anyone know how much total timing the original advance mechanisms supply? I am trying to come up with a good timing curve and am curious about the total timing. | | | | | Joined: Nov 2020 Posts: 71 'Bolter | | 'Bolter Joined: Nov 2020 Posts: 71 | For some reason my phone didn’t want me to say I have modified my distributor to a two wire magnetic pickup. | | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 | Depends on the distributor. What is the delco number and year of your distributor?
Mike
| | | | | Joined: Nov 2020 Posts: 71 'Bolter | | 'Bolter Joined: Nov 2020 Posts: 71 | Engine is a 1960 truck engine that has hydraulic lifters installed. I have no clue what the distributor came out of. | | | | | Joined: Feb 2000 Posts: 5,221 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,221 | A lot of the vacuum units are marked, look to see if it has a number stamped in it. Any where from 16 to 24 or more. | | |
