1 members (ronsway),
185
Mod | | | Forums66 Topics128,167 Posts1,057,019 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | None of the local FLAPS or the local hardware store has the brass fittings to fit a 53 fuel pump. Looks like I'm going to have to order some on line. I know the male is 1/8 NPTS but I don't know the female/flare side size. I did find 1/8 male by 1/4 flare female and it was too large so I'm assuming it's 1/8x1/8 but I'd like to verify that before ordering. Help?
| | | | | Joined: Feb 2004 Posts: 29,868 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,868 | I believe the metal lines are 5/16" OD with an inverted flare nut. You would need a 1/8" pipe male to 5/16" inverted flare female fitting to adapt to the line from the pump to the carburetor. Check the fuel pump end of the flexible line from the frame to the pump- - - it might be able to screw into the pump directly if it's got a 1/8 NPT male thread. Another approach might be to install a 1/8 NPT male to 1/4" or 5/16" hose barb at the inlet and use a piece of flexible fuel hose and a small hose clamp as a flex line. My local Home Depot has all those fittings in stock. Measure the OD of the metal line with a pair of dial calipers - - -5/16" is 0.3125", and 1/4" is 0.250". Jerry
| | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | I had a fairly serious leak from the pump that tightening the fittings didn't fix. The new pump rebuild kit will be here today for me to rebuild the pump but I'm wanting to put new fittings on it as well just to cover all the bases. If 1/8 male x 5/16 inverted flare female is what I need that's what I'll get. Thanks.
| | | | | Joined: Jan 2014 Posts: 3,690 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,690 | It’s silly that you can’t just go to any old parts store and find this stuff. But I have experienced exactly the same thing.
1951 3100
| | | | | Joined: Feb 2019 Posts: 4,503 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,503 | Jerry is correct. I just changed mine and it is 5/16” inverted flare with a 1/8” male NPT. Bring you fuel pump and fuel line to NAPA, and they will have everything you need.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Jan 2014 Posts: 3,690 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,690 | Preserving this info for myself and future generations.
My Napa store located these fittings in their Weatherhead catalog:
Part # 202X5 - 5/16 female inverted flare to 1/8 male NPT
Part #352X5 - 5/16 female inverted flare to 1/8 NPT (45 degrees)
I’m re-plumbing my fuel pump to correct a leak. Wonder if the 45 degree job might unclutter the traffic jam with the fuel line, vac advance line, and draft tube. It’s an expensive little devil.
1951 3100
| | | | | Joined: Nov 2002 Posts: 2,767 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,767 | Local NAPA had them all last year, have not checked this year.
I stock them all, as include several different fittings when I sell a carburetor.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | Wonder if the 45 degree job might unclutter the traffic jam with the fuel line, vac advance line, and draft tube. It’s an expensive little devil. This is strictly a guess but I wonder if the 45 deg. fittings aren't offered as a way to use an earlier fuel pump with the straight across ports on a later engine where the ports are angled. Anyway the rebuild kit came in and I spent an hour today trying to get the new diaphragm to "hook" to the lever that rides on the cam. I had to walk away and cool down before I did something expensive. I've always been quick to anger so I don't deal with that type of situation well. I'll get it eventually but if anyone has a magic bullet solution I'm all ears.
| | | | | Joined: Jan 2014 Posts: 3,690 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,690 | For what it’s worth, the 45 degree fitting did not work with my combo of later engine, straight through pump, and draft tube. But it might be handy for someone.
1951 3100
