1 members (frogfarmer),
116
0
Mod | | | Forums66 Topics128,109 Posts1,056,268 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11,067 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,067 | So the $20 Harbor Freight angle grinder I bought at least 5 years ago let the smoke out today. I had to break out my spare $20 HF angle grinder to finish the job. Not bad service for a cheapskate like myself.  Here's a video of the carnage.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Before the guys went to nearly all battery tools we bought the dickins out of HF air tools. With paint prices out of sight one can't oil air tools so we used them dry. Life was short. Now the walls and benches are cluttered with battery chargers but very few fish eyes in paint.
Evan
| | | | | Joined: Feb 2004 Posts: 29,804 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,804 | When I was teaching auto body classes at an inner-city Nashville high school, we had terrible problems with fisheyes in several paint jobs. I finally tracked down the source of the problem. At least a third of my students were using large quantities of Vaseline Intensive Care lotion on a daily basis. They called it "ash killer"! Sanding body filler and then rubbing their hands over the freshly-sanded surface feeling for ripples was putting the lotion deep under the primer and the finish paint. Jerry
| | | | | Joined: Nov 2018 Posts: 122 'Bolter | | 'Bolter Joined: Nov 2018 Posts: 122 | Kevin - I keep two spare HF Angle Grinders in my tool cabinet, buying them when they are on sale. A lot cheaper than the other big box store brands!! You're not a cheapskate, you're just being frugal!! More money to spend on truck parts.
Charlie
'51 3100 5-Window (Restomod in progress)
| | | | | Joined: May 2015 Posts: 11,067 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,067 | Frugal! Yeah, that's the ticket.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | LOL I bought a Grinder at least 25 years ago from a Truck Load Tool Sale (we didn't have HF back then). It was 5 dollars and came with 5 grinding wheels. Somewhere along the way someone gave me another one. Well the bearing in one went out and I bought a $3 bearing at the hardware store that fit perfectly. the next issue I had was the switch went bad. Tore it open and it was a double pole Switch well I made it a Single pole cause one side still worked! I have spent more money on Cut off wheels, Wire Wheels and Diamond Wheels then I have on Grinders. I bought it as a use it and Throw it away when done...... guess I ain't done with it yet! LOL
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | | | | Joined: May 2015 Posts: 11,067 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,067 | It's ALIVE AGAIN!!!  I (of course) opened it up and discovered that the rear bearing (near the brushes) had seized up and spun in the housing. So I went down to the local bearing supply and bought a replacement bearing. Used a little epoxy to reinforce the housing around the bearing and set it aside to cure. Today I plugged it in and nothing, so tore into it again and discovered that one of the brushes was hanging up. Fixed that and it roared back to life. So I still have a spare.
