3 members (RLB, qside, Gray_Ghost), 71 guests, and 1 robot.
Topics128,072
Posts1,055,907
Members48,429
#1403436 03/28/2021 4:20 PM
Does any one know how high I need too raise one end of the axle higher than the other to prevent the grease to run out when pulling the axle?
higher than you may think, probably 5-6 inches.
Lots more pictures
Most hubs have a reservoir built into them between the two bearings, so jacking up a wheel usually doesn't help prevent spillage. Just put something like the pan used for baking a loaf of bread under the axle flange to catch the spill. No, borrowing one from the kitchen cabinet IS NOT a good idea! Ask me how I know!
Chris's46/515 Have found it is best to not fill the differential chock full-running over put the plug in !!! If you do that it puts more oil out there than the seal likes to handle. Especially in hot weatherand on a long trip. I think the service book says OK to be 1/2 inch below the plug hole cold and level,then can expand some. When you drive and get not level both ways the hubs fill their pocket and lube bearings and seasls.
I drained the grease, now I need to find those lock washers in between the bearing nuts. NAPA was no help. Anyone have a source?
Chris's 46/ 515 Probably have to find them on swap meet, maybe others will chime in with some spares.
The W- 11 bearing nut lock washers are close but crimping fingers aren't long enough, I would think there would be a new stock source.
Will this one work?
https://www.ebay.com/itm/NOS-GM-473629-Rear-Wheel-Hub-Nut-Lock-Washers-1936-1952-85-02-Chevrolet-Truck/114621878356?epid=671672284&hash=item1aafff1054:g:YF8AAOSwsm5f-gnL
Lots more pictures
Originally Posted by Paul_WNC
Will this one work?
Nice find Paul!
Just to confirm, per my parts books they are correct for your 1946 COE...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Paul: You are the man! Have two on the way. Thanks
