| | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2010 Posts: 476 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 476 | Does any one know how high I need too raise one end of the axle higher than the other to prevent the grease to run out when pulling the axle? | | | | | Joined: Nov 2011 Posts: 1,609 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,609 | higher than you may think, probably 5-6 inches. | | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | Most hubs have a reservoir built into them between the two bearings, so jacking up a wheel usually doesn't help prevent spillage. Just put something like the pan used for baking a loaf of bread under the axle flange to catch the spill. No, borrowing one from the kitchen cabinet IS NOT a good idea! Ask me how I know! Jerry
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Chris's46/515 Have found it is best to not fill the differential chock full-running over put the plug in !!! If you do that it puts more oil out there than the seal likes to handle. Especially in hot weatherand on a long trip. I think the service book says OK to be 1/2 inch below the plug hole cold and level,then can expand some. When you drive and get not level both ways the hubs fill their pocket and lube bearings and seasls. | | | | | Joined: Feb 2010 Posts: 476 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 476 | I drained the grease, now I need to find those lock washers in between the bearing nuts. NAPA was no help. Anyone have a source? | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Chris's 46/ 515 Probably have to find them on swap meet, maybe others will chime in with some spares. | | | | | Joined: Feb 2010 Posts: 476 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 476 | The W- 11 bearing nut lock washers are close but crimping fingers aren't long enough, I would think there would be a new stock source. | | | | | Joined: Nov 2011 Posts: 1,609 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,609 | Will this one work? https://www.ebay.com/itm/NOS-GM-473629-Rear-Wheel-Hub-Nut-Lock-Washers-1936-1952-85-02-Chevrolet-Truck/114621878356?epid=671672284&hash=item1aafff1054:g:YF8AAOSwsm5f-gnL | | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | Will this one work? https://www.ebay.com/itm/NOS-GM-473629-Rear-Wheel-Hub-Nut-Lock-Washers-1936-1952-85-02-Chevrolet-Truck/114621878356?epid=671672284&hash=item1aafff1054:g:YF8AAOSwsm5f-gnL Nice find Paul! Just to confirm, per my parts books they are correct for your 1946 COE... Mike B  | | | | | Joined: Feb 2010 Posts: 476 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 476 | Paul: You are the man! Have two on the way. Thanks | | |
