| | | Forums66 Topics128,259 Posts1,058,291 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | I'm looking at a block that is .145 to .400 according to the sonic test. Would like to go .050 over, which means I'd be at .095 at the thinnest? Is that acceptable? | | | | | Joined: Dec 2008 Posts: 1,923 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,923 | 1. .050" only removes .025" from each surface 2. the thrust surfaces must be substantially thicker than the pin axis sides 3. for a street engine I like to see minimum of Passenger side .150" Driver side .120" Crank axis .090"
Any rougher use needs more thickness | | | | | Joined: Feb 2004 Posts: 29,940 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,940 | Your minimum thickness will be .120", not .095 with a 50 overbore. Back before the days of sonic testing, nobody worried about anything below 60 over, and the people who contracted rebuilding services to places like Sears and J.C. Whitney routinely went 80 0ver. If you're concerned about a thin spot, install a sleeve. I've repaired golf ball sized holes in cylinder walls with a .125" wall sleeve, and built 500+ HP round track engines with those blocks.
My father used to bore flathead Ford V8's .250" oversize by offsetting the cylinder centerline away from a thin area where the exhaust passed between the center cylinders and narrowing the small end of the connecting rod so the piston could center up in the cylinder. Then he ran them with 11:1 compression on alcohol! Jerry
| | | | | Joined: May 2015 Posts: 11,262 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,262 | Just a point of interest, I've seen lots of Model A blocks that were bores 100 or even 120 over. Of course there was probably a lot more iron in those back in the 20's and 30's.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2004 Posts: 29,940 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,940 | Isn't there a 3 7/8" diameter Chevy V8 piston that some people run in the Model A engine? That's a 1/8" overbore. jerry
| | | | | Joined: May 2015 Posts: 11,262 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,262 | Isn't there a 3 7/8" diameter Chevy V8 piston that some people run in the Model A engine? That's a 1/8" overbore. jerry Don't know, as it's been almost 50 years since I messed with a Model A engine, but I think I saw 125 over stock style pistons available. I wouldn't be surprised if someone used Chevy V8 pistons in one of them.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2004 Posts: 29,940 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,940 | I'm tinkering with one of those engines- - - -thinking of adapting a dual overhead cam cylinder head to it from a MOPAR 4 cylinder. Jerry
| | | | | Joined: May 2015 Posts: 11,262 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,262 | Those were pretty torquey engines, kind of like a tractor. I think the stroke was 4 inches or so. Displacement of 200 CI for a 4 cylinder would be equivalent to a 400 CI V8. I ran a Model C engine in my first pickup, basically the same except bigger crank journals, counterbalanced crank, and a higher compression head. I know you could dump the clutch in high gear and not stall the engine. The guys on tour in the Model A club were jealous, because I was at half throttle when they were on the floor. A DOHC Model A engine would be interesting. It'll take some machining to develop a drive for the cams.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I’m sure someone in years past has developed A DOHC Model A head, they developed many other alterations.
Ed
| | | | | Joined: Feb 2004 Posts: 29,940 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,940 | Rajo and Frontenac made OHV heads, not sure about any DOHC conversions. Really, it would be fairly simple to adapt a belt drive setup to the front of the engine- - - -just sprockets, idlers, a tensioner, and a belt. No worries about the mesh of the crankshaft and cam gears, etc. That would make line boring the block for insert main bearings a simpler process, as well. I'm looking at a 2.4 Liter PT Cruiser head as a possible donor. Jerry
| | | | | Joined: Jul 2008 Posts: 326 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 326 | HRL;
"2.4 Liter PT Cruiser head as a possible donor".... How would that work? I don't know if the bore centers are even close. Regardless it would be mic drop moment when opening the hood.
SimS | | | | | Joined: Dec 2008 Posts: 1,923 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,923 | The "A" has a huge gap between the #2 & 3 cylinders to accommodate the center crank bearing. | | | | | Joined: Feb 2004 Posts: 29,940 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,940 | It would require a little creative machining of an adapter plate, and probably custom pistons. For a running prototype, I'd rivet or bolt an aluminum shim to the top of the piston to take up the combustion chamber volume increase created by the adapter plate. Jerry
