| | | Forums66 Topics128,142 Posts1,056,490 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 204 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 204 | I know I have many issues with my 55.1 235 engine as far as oil consumption and smoke. I found a mechanic sort of local who will look at it and i'm sure he is going to ask me questions about the motors behaviors. So i will tell him what I think I know, but i don't know why it runs great with some smoke and than after three months runs like poop and smokes like crazy. I change the #5 spark plug and it all gets better. So much oil on that plug, but compersion is close to other cylinders. I will ask him to do a leak down test as per advise from other bolters and if he dosen't do leak down test I will try to find another mechanic. Most of them say "put a 350 in it" | | | | | Joined: May 2015 Posts: 11,078 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,078 | The oil control ring on that cylinder could be bad. That would let oil by and compression could be similar to other cylinders. A new ring set on that cylinder may fix it up.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2004 Posts: 29,820 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,820 | Use a borescope through the spark plug hole to look for score marks in the cylinder. A ring cannot seal properly if there are scratches that let the oil bypass the rings. Also, a worn intake valve guide and/or valve stem seals that let oil trickle down the valve stem can create pretty noticeable oil consumption and plug fouling. DO NOT let anyone convince you to install something called a "spark plug anti-fouler"- - -a spacer that moves the plug away from the combustion chamber. It also lets the plug overheat and burn the electrodes away in a hurry. Jerry
