3 members (Nick in Manitou, CuzzFuzz, Tronman), 115 guests, and 2 robots.
Topics128,080
Posts1,056,314
Members48,442
#1403029 03/25/2021 11:13 PM
I know I have many issues with my 55.1 235 engine as far as oil consumption and smoke. I found a mechanic sort of local who will look at it and i'm sure he is going to ask me questions about the motors behaviors. So i will tell him what I think I know, but i don't know why it runs great with some smoke and than after three months runs like poop and smokes like crazy. I change the #5 spark plug and it all gets better. So much oil on that plug, but compersion is close to other cylinders. I will ask him to do a leak down test as per advise from other bolters and if he dosen't do leak down test I will try to find another mechanic. Most of them say "put a 350 in it"
1955 First series 3600 3/4-ton
"A Great Starting Point"
Follow the story and pix in the DITY Gallery
The oil control ring on that cylinder could be bad. That would let oil by and compression could be similar to other cylinders. A new ring set on that cylinder may fix it up.
Use a borescope through the spark plug hole to look for score marks in the cylinder. A ring cannot seal properly if there are scratches that let the oil bypass the rings. Also, a worn intake valve guide and/or valve stem seals that let oil trickle down the valve stem can create pretty noticeable oil consumption and plug fouling. DO NOT let anyone convince you to install something called a "spark plug anti-fouler"- - -a spacer that moves the plug away from the combustion chamber. It also lets the plug overheat and burn the electrodes away in a hurry.
