1 members (Hotrod Lincoln),
41
0
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#14029 10/25/2004 8:28 PM | Joined: Sep 2004 Posts: 31 Apprentice | | Apprentice Joined: Sep 2004 Posts: 31 | Timing gear 54 235 Finally gonna get into it any tricks I should know about what holds the crank pully on,it feels like a hole instead of a bolt I will replace main seals and clean pump screen anything else | | |
#14030 10/25/2004 11:49 PM | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | The crank damper is a press fit. Use a puller bolted into the threaded holes in the center hub, and DON'T hammer on the outside ring of the damper. You'll break the pulley section loose from the rubber ring that separates it from the hub. To reinstall it, use a driver that puts the hammer blows on the center hub, and use a heavy sledge and medium-force taps to force-fit it back onto the crankshaft. While you're in there, it's a good idea to convert the two bottom holes in the timing cover to bolts threaded in from the front, rather than having them come through from inside the oil pan. There's probably a procedure archived somewhere on this site for that procedure. Jerry
