1 members (Hotrod Lincoln), 88 guests, and 5 robots.
Topics128,014
Posts1,055,325
Members48,419
#1402276 03/20/2021 11:12 PM
Crusing in the Passing Lane
On my 55.2 GMC, I have pulled gently on the switch while pushing on the spring loaded button on the port side of the switch. All positions of switch button(all the way in, first notch, all the way out) have been tried, no joy. Am I missing something, or is it likely clogged with dirt( both devices move easily) or something else?
Th@nks,
Edi
EdPruss #1402279 03/20/2021 11:17 PM
AD Addict & Tinkerer
Try twisting it one direction or the other as this worked for me.
Phil
Project Journals
Stovebolt Gallery Forum
Phil,
Thanks, I have been trying that, I will keep at it.
Ed
I’d keep working on the button while pulling and turning on the knob. The button likely is rusted etc and is not releasing. Perhaps if there’s an opening some light oil may help. Don’t pull too hard or you may break the tang holding the switch on. I know by experience!
Moderator, Electrical Bay
Ed, sometimes the bakelite slider inside will break (usually partially but recently I ran across one that broke completely) and that will make things pretty horsey. One, the switch won't work well any longer. Two, you can't get the knob out occasionally. If you go back several posts, you'll see a tutorial I made showing how to disassemble these and repair/rebuilt them. I was hoping that might become a sticky or a tech note, but guess not. Once you do that, they usually work just like new. Good luck.
~ Jon
Jon,
Thanks, I have been working mine gently every time I go outside, turning the knob every time, no joy. I will look up your post.
Ed
