4 members (baldeagle, Simon1954, klhansen, Joe H), 85 guests, and 11 robots.
Topics128,019
Posts1,055,343
Members48,419
#1402024 03/19/2021 3:27 PM
Had a 1954 235 rebuilt for my truck. Everything replaced, rebuilt or new. Runs great, except, when cold, or when mashing the gas at higher rpm, she hesitates and coughs. Fuel lines and filters good, everything good, except the sputtering at higher rpms. Carb adjustment? Timing? What first? The carb was rebuilt along with the motor. Any suggestions would be helpful.
JS
Pieman #1402030 03/19/2021 3:54 PM
Check the spring tension on the points. It sounds like you're getting "point bounce" at high RPM, resulting in erratic ignition timing. If you're running some sort of aftermarket electronic ignition, all bets are off!
Pieman #1402503 03/22/2021 1:24 PM
This also sounds like typical Rochester B performance,
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
Pieman #1402507 03/22/2021 2:17 PM
AD Addict & Tinkerer
Timing or vacuum advance possibly.
Phil
Project Journals
Stovebolt Gallery Forum
Pieman #1402543 03/22/2021 6:55 PM
What kind of air filter are you using?
Mike
