0 members (), 80 guests, and 0 robots.
Topics128,050
Posts1,055,644
I want to lower my 1953 Suburban 2"- 3" and soften the ride. I've had a couple of shops tell me to remove 3 springs from the rear and 4 springs from the front. Has anyone done this? How was the ride/
Removing springs from the rear will not lower the truck but should soften it some. In the rear you can use a simple lowering block. In the front I am using a mono leaf which actually makes it handle real nice. Then it is up to a matching gas shock to help the ride.
54 3100 with 235
62 flatbed dump C60 with 261
These guys can make you some springs. Eaton Springs
It would be the more correct and safer way of lowering but, it's a bit expensive. This would get you lower and a nice ride. If you want a 3" drop, you may have to add a 1" lowering block as the springs alone will give you about 2". If you plan on keeping the truck for a while, might be worth it.
Lowering blocks create undue stress on the rear axle. Creates a torquing and twisting effect. I temporarily installed 3" lowering blocks on my Pontiac and it put a HEAVY arch in those old springs. I only drive it once a week and it's got a no torque 239ci. When I install a hopped up 292, I'm definitely getting new springs.
Tradin' up dimes for nickels...
My \'65 Chevy C-20
